1987 Carver 3697 filler neck and overheat
- carver3697'87
- Vessel Info: 1987 Carver 3697 Mariner
- Has thanked: 1 time
Re: 1987 Carver 3697 filler neck and overheat
If you think there was enough pressure to cause physical damage, then you should test and/or replace the cap. They should release any pressure that gets over about 15 PSI.
When did the actual overheat happen? Was it up at cruise or after a cruise? How long do you think it was actually HOT before it overheated? Did you get any alarms?
