Kohler 7.5R crank, but no start
- VicB
- Vessel Info: 1988 Carver 3807
- Has thanked: 41 times
- Been thanked: 11 times
Vic
- ColRon
- Has thanked: 77 times
- Been thanked: 157 times
Re: Kohler 7.5R crank, but no start
B. Unit cranks but will not start.
1. No fuel.
2. No spark (Section 11).
3. Open foil, loose or broken pin on circuit board (Section 5).
4. Open or ground in harness assembly (Section 5).
5. Faulty circuit board (Section 5).
6. Faulty "1CR" relay (Section 5).
7. Poor compression (Engine Manual, ES-652).
8. Valve problems (Engine Manual, ES-652).
G. Unit Lacks Power
1. Improper fuel (Section 1).
2. Fuel mixture wrong (Section 9).
3. Poor ignition (Section 11).
4. Improper cooling (Section 10).
5. Poor compression (Engine Manual, ES-652).
6. Valve problems (Engine Manual, ES-652) .
7. Carbon build-up (Engine Manual, ES-652) .
8. Set overloaded (Section 1).
“Escape Plan”
Murray, KY
