Sealant to seal rubber /neoprene boot to au
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Postby tonyiiiafl » October 30th, 2023, 6:51 pm
Season 2 for my Side Shft bow thruster. It is by far the best improvement I ever installed. Customer service is the ost paramount I have ever encountered. I replaced a couple of bands this weekend. WHen I did, it appears the cables loosened up where they connected to the thruster. To tighten, I had to pry the neoprene boots (There is one on top of another. off of the thruster motor to get a wrench on the nuts. Side Shift has been so gracious to me. Cant say enough great about the company. Anyway they are sending me new neoprene boots. I wil need to slide them over the cable, and then use marine adhesive to put between the motor and the boot. What would you all use? Side shift said the use Silkaflex, but any good sealant wil work, like 4200 or even 5200/ So, fire away with what you would use.
Re: Sealant to seal rubber /neoprene boot to au
Postby Viper » October 30th, 2023, 6:58 pm
I would not use 5200.
Postby bud37 » October 30th, 2023, 7:19 pm
Tony, my advice, use what they recommend.
tonyiiiafl
Postby tonyiiiafl » October 30th, 2023, 7:43 pm
Agree. I need to ask what type sikaflex. It was still on there solid after 2 years
