'89 Santego, AC problem
- bobwhorn
- Vessel Info: 1989 Carver Santego 3867. Repowered with Cat 3116s in 1993.
- Has thanked: 3 times
- Contact:
Thanks for any input,
Bob
Re: '89 Santego, AC problem
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
- bobwhorn
- Contact:
The lower step has a panel with the battery selector switch and the breakers for the bilge pumps built into it, so it doesn't look like it would be easily removed.
Bob
- ColRon
- Has thanked: 77 times
- Been thanked: 157 times
“Escape Plan”
Murray, KY
- bobwhorn
- Contact:
Bob
- ColRon
“Escape Plan”
Murray, KY
- bobwhorn
- Contact:
What size AC units do you have on your boat and what size sea water pump? Our two 16K units are a bit too much for the 500 GPH pump. The unit in the cabin is new so it may have been replaced with a bigger unit.
- ColRon
bobwhorn wrote:Glad to know there is a way to replace the unit without cutting a hole in the bottom of the boat, The previous owners had the boat set up as an AirBnB, until the marina found out, anyway. The had all the upholster redone, inside and out and all new carpet. They were into appearance, maintenance not so much, so I'm pretty sure the carpet on the stairs is glued down.
Bob, I also have two units. The one in the salon is a 16k unit, while the one in the state room is a 12K unit. I just replaced the one in the state room 2 years ago after the one original to the boat gave up the ghost. The Salon unit was replaced by the previous owner. I know the unit in the state room was original as I have the dealerships delivery checklist when the boat was first sold and the serial numbers on the check list and the unit matched. 30 plus years were on that old Marine Air unit, but when i brought the boat, I knew it was a question of when and not if.
As far as the size of the water pump, I'm not sure on its size. It is located in the bilge in front of the steps, but I've never checked to see what size it is. Next time i am at the boat i will check and see if I can determine its size.
“Escape Plan”
Murray, KY
If it was flowing a full 500 GPH (which they never due because of restrictions), then it's about 4,000 BTU for every degree F in temp that the water goes up flowing through the system. So to get 32,0000 BTU (two 16k units), you'd need a **minimum** of 8 degrees temperature rise. In reality, you might have half the 500GPH, so that would need a 16 degree rise. TEN is typically what's expected as a max. When you're starting in water 10F cooler, it's easy to get 10F rise. In water 10F hotter, it's much harder.
Users browsing this forum: No registered users and 7 guests
