Need electrical help
- David Barclay
- Vessel Info: 1999 Carver 356 aft canin
- Has thanked: 2 times
Thanks,
David
Re: Need electrical help
- David Barclay
This is what is making all of the noise. Is this a transfer switch??
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
I do have a bigger genset than you, but 6.5 should easily be able to power both AC units, unless you are pulling a lot of other power, maybe using the stove while the water heater is kicking in.
One thing I might suggest, when you need both AC units running, turn on the bigger one first and then the aft unit second. Reason for that, the smaller unit will have a smaller electrical surge than the bigger one. With the bigger one already running, it just might work.
- David Barclay
I've often thought about putting in a contactor in the water heater circuit, so that if the range or big A/C compressor is on it cuts the water heater off automatically during that time.
- buster53
- David Barclay
David Barclay wrote:Source of the post
Yes that is the transfer switch I was referring to. Check the connections, and check the output voltage when the generator is running, especially when a heavy load kicks in. If the voltage drops considerably, that might be your problem. Again, that might be the result of poor/loose/corroded connections, bad relay (transfer switch), or poor generator output which could be due to a few things. Also check the surfaces of the contacts on the relay. If they are corroded or burnt, you'll have the same symptoms.
- Has thanked: 602 times
Is it right to assume you are away from the dock power ?
A/C equipment etc gets old and may be drawing too much power on start up .......
The marine electrician sounds like a good idea to me as these things are very hard to diagnose in a forum setting unless someone has had the exact same occurrences.
