Hello Everyone! Buying a 330 Aft Cabin
- bthomas70
- Vessel Info: 1991 330 Aft Cabin
Also, the survey noted that the escape hatch in the aft cabin appears to be fixed. Is that normal? Maybe we are missing something.
This is a great forum, and we are very appreciative of all the information you share.
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: Hello Everyone! Buying a 330 Aft Cabin
- Been thanked: 654 times
- Been thanked: 490 times
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- Has thanked: 602 times
Really you can get a raw gas/ fuel smell after a boat has been sitting if a carb is leaking into the intake and a few other things......hoses and fittings are all replaceable easily, carbs can be rebuilt easily ...the one issue with an older boat is the fuel tanks corroding in hard to get to places. These are not easy to replace and can be an extremely expensive repair, just go slow here and cross things off the list.
Could even be the fuel tank vents, boat interior heats up and creates a chimney effect pulling air from outside. Lean on your surveyor and mechanic to help. Good luck going forward.
FYI...it only takes a very/very small amount of fuel for the human nose to detect the vapour.
EDIT..... Just to add, gasoline fuel leaks can be explosive under the right conditions so be careful if there is one and have your mechanic check ground/bonding continuity between the fuel fill fitting and ground system while you are at it.
- plittle2005
- Vessel Info: 1992 Carver 350 Aft Cabin
- Has thanked: 16 times
- Been thanked: 37 times
One cup of gasoline, fumed, is equal to 6 sticks of dynamite, I'm told. I have survived a gasoline explosion.....never again!!
If gasoline leakage is detected, I personally would continue to shop...lotta nice 33's out there! But that's just me!
My 33 passed the above, so far it is fine, but I always inspect the engine room immediately after shutdown, for gas odor, oil level, exhaust system elbow/riser/hose "touch" temperature.....too hot to leave your hand on means it's over 120 F...bad for the hoses and silencers.
And yes, the aft cabin "escape hatch" is non-removable. So if we are trapped by fire in the main cabin, I keep fire blankets back there and a large fire extinguisher to (hopefully!) use to smash out the plexiglass. I have not yet found an opening window kit.
Good hunting! It's a great layout.
Phil Little
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
- bthomas70
My wife and I are excited about the boat and we're glad to join the Carver family. I'm sure I'll have more questions. Thanks again.
Users browsing this forum: No registered users and 72 guests
