Rotten egg smell from hot water - HELP
- tgebler
- Vessel Info: 2000 396 AC
- Has thanked: 5 times
- Been thanked: 29 times
Thanks for your suggestions and comments.
- Has thanked: 602 times
Re: Rotten egg smell from hot water - HELP
- mjk1040
- Been thanked: 248 times
- Rocketman
- Vessel Info: 2009 44 Sojourn w/ Volvo Diesel D6-500 engines and IPS drive system.
- Been thanked: 24 times
Take and flush your hot water heater really good by running the shore water supply thru your tank for about 10 minutes by opening all the faucets onto the hot side and letting it flush.
You need to disconnect your hot water heater from your system.
Pour a cup of bleach into the hot water heater thru the intake port of your hot water heater. You can do this by opening the pressure relief valve to allow the bleach to enter.
Let it sit for 1 hour.
Then take a small box of baking soda and mix w/ a gallon of water and pour into the hot water heater.
Let sit for 1 hour.
Reconnect and flush for 10 minutes.
You should be good to go and no more smell.
This happens a lot when you winterize the system and don't get all the water out of the tank or let it sit for several months without any water going thru.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 138 times
Stopped using the onboard water system and only connect to marina water, unless I am going to be cruising for a few days.
As liveaboards we took the opposite approach: we never use the external marina connection but instead use only the onboard holding tanks. This way the water in our holding tanks is getting "turned over" every 4-6 days and stays "fresh".
With our approach we have never had any odors with our water system. I will flush the external connection occasionally, but it's like most things in boating - you gotta figure out what works for your style of boating.
2002 Carver 396
A tablespoon of bleach in a full tank of water periodically throughout the season is all you need to keep the system fresh, and that concentration won't harm your hardware or you while using it. If you drink your potable water, additional considerations are in order.
- KyleR
2002 Carver 396
Excellent point! We use a Berkey water filter for all our drinking/cooking water. I know it's off topic, but thought I'd throw it out there.
2002 Carver 396
