Aft transom window 3807
Gilligan 1955
Vessel Info: 1989 Carver 3807
Postby Gilligan 1955 » August 5th, 2024, 8:39 pm
I recently purchased a 89, 3807. In the survey it was noted that the aft transom window should be replaced with one that opens so it can be used as a second point of escape. Is it possible that the window is made to "pop out" when hit with sufficient force? Really don't want to replace with one that opens thus adding another point for future water leaks.
Re: Aft transom window 3807
Postby km1125 » August 5th, 2024, 10:20 pm
Surprised something like that showed up in a survey. There are a LOT of very nice mid-cabin boats that only have a single point of egress. The 470 Sea Ray comes to mind but there are numerous other similar examples.
Postby bud37 » August 6th, 2024, 7:52 am
It may just to be the ability to avoid passing the engine compartment on the way out.
Postby g36 » August 6th, 2024, 6:57 pm
Tie a small hammer like you see next to a fire extinguisher with sign on window that says "break in case of emergency.".. :-D
Been thanked: 490 times
Postby waybomb » August 6th, 2024, 9:10 pm
It stated should, not shall. I'd ignore it. I know if I tried to get through a small wind like that, I'd get stuck. I have a much better chance of swimming up and out the stairs.
Lets say you were sleeping back there. Safe to assume tied up in a slip or on anchor. The boat is not going down in any short time. You'll have time to get out.
The surveyor probably feels he has to list something to make it worth your while. I've dealt with x-spurts my entire career. They must justify their pay. (x is an unknown ; a spurt is a drip under pressure)
Postby Viper » August 6th, 2024, 9:58 pm
Ya there's recommendations, then there's red flagged must do's. The issue is whether your insurance company is one that will make you act on the recommendations as well as the must do's. If they've already insured you without correcting that recommendation then I wouldn't worry about it unless it bothers you personally for safety reasons.
bsan42
Vessel Info: 1988 3807
Been thanked: 3 times
Postby bsan42 » August 7th, 2024, 10:29 am
According to my brother, who was Carver's biggest dealer at the time, that window was indeed intended to be popped out as an emergency exit I had asked him the same question when I bought my 3807).
Postby Viper » August 7th, 2024, 1:10 pm
Good to know! :down:
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 153 times
Been thanked: 138 times
Postby KyleR » August 7th, 2024, 5:40 pm
:lol: That's a keeper!!
MV Verity
2002 Carver 396
plittle2005
Vessel Info: 1992 Carver 350 Aft Cabin
Has thanked: 16 times
Been thanked: 37 times
Postby plittle2005 » August 11th, 2024, 6:48 pm
In my fixed window '92 3307 AC, I keep an 18"x1"dia steel bar lying on the floor next to the bed. We also have 3 fire extinguishers an 2 fire blankets for if there is a fire in the main salon. We also have a fire blanket fwd and 2 extinguishers in the v-berth, 3 more in the galley/main area.
Users browsing this forum: Google Adsense [Bot] and 42 guests
