1994 390CPMY water heater replacement
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
heater Seaward 1100 dropped into the hatch under the dinette. Pull and tug, and slide into position. LOTS of room (inch plus on each side!) screwed it down, hooked up rear heat exchanger hose. Then back to the engine room and connected the hoses to the engine. (If I did it again, I would have filled the hoses with coolant before connecting them. Then wired it up, and started the engine. coolant dropped a bit but nothing as I thought it would. However, after bringing the engine up to temp for a few cycles, i shut off and loosened the clamps on the rear of the heater where the hoses meet heat exchanger. Coolant came out of both. Ran up to temp a few times more and added another pint of coolant. Hoping it drops overnight a bit. Painted it also.
Took the old heater apart, found it was a bottom seam leaking. When I dumped the heater out, it was like a beach came out! Unknown where all that sand came from.
Water heated well with heat exchanger, and also electrically. Total time from start to end was approx 6.5 hours. Like I said, no it a bad project at all!
PS : Start at the bottom for the pictures, They were added in reverse!
Re: 1994 390CPMY water heater replacement
Good job Tony
- Been thanked: 654 times
- tonyiiiafl
