Loss of RPM’s on both engines at wot
- Merkinbrumsky
- Vessel Info: 1985 Carver Voyager
- Has thanked: 53 times
- Been thanked: 38 times
Re: Loss of RPM’s on both engines at wot
- Merkinbrumsky
jumped up on plane and had her doing 27mph as opposed to 15mph yesterday before the filter change. O ring on the stbd fuel cap was missing. Going to get a replacement now.
- Alanna Mo Cree
- Vessel Info: 2003 360 Sport Sedan
Twin 8.1Gi Volvo Penta FWC - Location: Sanford, Florida
- Has thanked: 46 times
- Been thanked: 70 times
2003 Carver 360 Sport Sedan
Twin Volvo 8.1Gi
Photo Album
- Merkinbrumsky
- Merkinbrumsky
- Has thanked: 603 times
Quick question....how are you planning to pump the bottom out with, what will you use ? I have done this on this very boat many years back but it was in the parking lot on a cradle.
Actually what you got in the filter could have been accumulating bits at a time, over time. I guess you will see.
Be extremely careful with gasoline, enough said.
- Merkinbrumsky
bud37 wrote:Source of the post Good to hear ya got it running right.....
I have a fuel transfer pump…rated for gasoline. No spark. I was planning to shut down everything, bilges included. Unplug shore power as well. Open all 3 engine hatch’s. I was thinking of using a piece of pex on the inlet side to give it some rigidity so I know when it’s at the bottom, and pumping into a Jerry can or cans if needed. In reality I was hoping just to get the bulk of the water out if there is much and let the separators do the rest with frequent checks. Not sure how I feel about putting it away with an unknown quantity of water in that tank. Marina has suggested to me that I just let the fuel filters do their thing and change as needed.I’m open to any advice.
On the other hand, it is the end of the season and If you don't think you will burn enough off then by all means pump it out and start fresh, the fuel is much cheaper than an engine, burn it in your lawn stuff/ snowblower...
etc.There is always the thanksgiving cruise around Beausoleil.......
Merkinbrumsky wrote:Source of the post
... I was thinking of using a piece of pex on the inlet side to give it some rigidity so I know when it’s at the bottom, and pumping into a Jerry can or cans if needed. ....
I did something similar years ago. I was able to go in the fuel fill, as it was straight down. I used a 3/8" piece of copper tubing. You can put in whatever bends you need and straighten it out. You'll definitely know when you've hit the bottom of the tank too.
I wouldn't take the marina's advise to just run the engines without knowing how much water is in the tank. A little is fine but it's a different ball game if there's a lot of water. Pump out as much water as you can, then check the filters often until you don't see water anymore.
