Replacement props
- thisismurph
- Vessel Info: 1993 Santego twin 454 crusader engines
Replacement props
I'm looking to replace two damaged props on a 1993 340 Santego. 18 x 23 four blade 1 and 3/8 shaft Would love to find something used. Do I need to have the exact same prop or is there some wiggle room
Thanks!!
- Has thanked: 602 times
Re: Replacement props
thisismurph wrote:Source of the post Do I need to have the exact same prop or is there some wiggle room
Thanks!!
This will really depend on how your boat was running before the damage......did it get on plane smoothly and relatively quickly without drama, what was your max (wot) rpm on plane. If you can lay that out , a good prop shop can help you make a qualified decision.
A small change in prop sizing may not have too much effect but if you are at one end of the range or the other for your boat as it is now ( loading etc ) it can make quite a difference to running and efficiency.
- Alanna Mo Cree
- Vessel Info: 2003 360 Sport Sedan
Twin 8.1Gi Volvo Penta FWC - Location: Sanford, Florida
- Has thanked: 46 times
- Been thanked: 70 times
2003 Carver 360 Sport Sedan
Twin Volvo 8.1Gi
Photo Album
- MyPleasure
- Vessel Info: 1992 Carver 36 aft cabin with Volvo 740b engines. Westerbeke 5kw generator. Bought the boat in Portland Oregon in June, and a friend and I brought it up to Sidney, BC. Great trip!
- Has thanked: 2 times
- Been thanked: 23 times
We had a 36 Uniflite with 350 Crusaders, when we bought the boat, it would only run up to 3500 RPM, and get about 18 knots with zero vacuum, (some previous owner had installed vacuum gauges on both motors).The props were 18” X 22” 3 blade with 1 1/2” shafts. I got a set of 4 blade props from a prop shop in Anacortes that was going out of business, so I got a great deal on them.
I had a great conversation with a local prop shop, and we determined that we wanted to get the engines up to max 4200-4400RPM at WOT. They figured out that the best diameter and pitch with the 4 blade props would be 16” X 17”, which worked out perfect. The boat max RPM now was 4300 RPM, speed was now 26 knots, and I had 5” of vacuum at WOT.
While cruising at the same 8 knots, the RPM was about 200 more, but the engines had 10” of vacuum, and got better fuel mileage because the engines weren’t working so hard.
if you’re not getting full RPM out of an engine, even when fully loaded, then you’re working it too hard at any RPM.
Just my opinion of course
1st Carver 1987 32 Aft Cabin
3rd Carver 1995 350 Voyager
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
