Battery maintenance help
Carverlvr2
- Been thanked: 25 times
Re: Battery maintenance help
Carverlvr2
Ok. There’s the two OE chargers on the boat. A single bank that only charges the genny battery and (from what I’ve read) a three bank: a bank for each starting battery and one for the house battery plus the last PO added a second house (in parallel) to make that one big bank…easy enough, both are group 31 lead acid batteries and I’m assuming the same ah capacity. They’re also charged off the alternator(s).
Here’s the catch: The first owner added two SPP2150 Stinger AGM batteries for the stereo. They’re wired in parallel as one bank as well but the PO said they’re charged off the main charger too. That’s where I’m lost.
1. How can they be charged by the same bank on the charger as the two house batts but not all be wired together as one huge bank?
2. and each set possibly has slightly different ah capacities. The Stingers may be nearing 10yrs though.
3. And since the house is charged by the alternator, wouldn’t the stingers be too? Any insight is appreciated. I have 20+ yrs in automotive electronics but this is beyond my experience.
- Has thanked: 603 times
Once you get that all drawn out , then will be time to decide on new batteries if that is the direction you want to go in.....my two cents anyway......good luck with it..it will be worth it, trust me.
Carverlvr2
But as Bud says, you really don't know what you have until you trace it all out and figure out what's been done since it left the factory.
And 10 year old batteries are living on borrowed time. They might still have enough capacity for your usage, but only a fraction of what they had when new.
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 139 times
2002 Carver 396
KyleR wrote:Source of the post As an FYI, my OE house charger was a Charles charger and the data plate on it said it was for GEL type batteries only (see pic). It had been used for who knows how many years before me charging the house flooded lead acid batteries - probably not doing them any favors. But that's a different story. I never realized it until it died and I had to replace it. Just something to consider.
GEL batteries are definitely a different animal and need the appropriate charger.
Carverlvr2
- paulr
- Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
- Has thanked: 56 times
- Been thanked: 32 times
