1995 Carver 454 Cam Needed
Used boat parts, used Carver boat parts, trailers, dinghies, outboards, props...everything but the boats they were attached to. ALL ADS ARE FREE - USERS MUST HAVE AT LEAST 10 POSTS TO PLACE AN AD
Forum rules
All classified ads for boat parts are free. Please be as specific as possible in describing your item. You can upload pictures too!
CarverYachtOwners.com and the owners of this forum take no responsibility for the authenticity of ads or legitimacy of items being sold. Buyers, please buy responsibly.
To place an ad start a new Topic. We reserve the right to delete ads from users with fewer than 10 posts.
Bvick1969
Vessel Info: 1995 355 Aft
Postby Bvick1969 » January 15th, 2025, 7:27 pm
Looking for a new cam for the 454 Crusader cannot find one at parts store anywhere part number is RH RA 050015.
Can anyone guide me to a replacement? Located in Charleston Tennessee but will drive or pay for shipping.
Re: 1995 Carver 454 Cam Needed
Postby Viper » January 15th, 2025, 8:02 pm
Interesting, you'd think they'd be a dime a dozen for a 454. I can see it being a challenge if it's for a counter rotating engine though. Is it?
Postby tomschauer » January 15th, 2025, 10:50 pm
I wouldn't think a 1995 is counter rotation but it is certainly possible.
Maybe the problem is looking for a crusader part number? They may be discontinued.
I am not sure exactly how to direct you, but if you can verify it is a standard rotation engine, you should be able to use a mercruiser or a regular GM part number.
As viper mentioned, a cam should be pretty easy to find.
Good luck!
Postby Viper » January 16th, 2025, 8:32 am
I've been on 1996 boats with CR engines so thought it worth mentioning. Not many out there in that vintage but there definitely are some so this needs to be considered. Really depends on how many of these the boat builder still had in stock after the end of the CR production. I know for sure they are in some Carver built boats after 1995.
I agree with you Tom, I think the issue here is that the OP is trying to find a "Crusader" part. It's a GM part and I'm pretty sure a good engine rebuilder, especially one that specializes in marine engines should be able to source a replacement. I say "marine" because they may already know the cross reference for the Crusader part number, be it a cross referenced GM number, Merc, Volvo, etc. Failing that, they should be able to match the cam based on the series/variation 454 in question. You should be able to get that info off of a Crusader dealer based on your serial number. A crusader dealer should also be able to supply you with a cross referenced cam IMO.
Been thanked: 248 times
Postby mjk1040 » January 16th, 2025, 12:25 pm
I know here in NY 454's are hard to come by do to Marine & Racing applications, Last I knew Jasper Engines (Which I wouldn't consider buying) was pay $ 1,600.00 for any good 454 block. My consern would be replacing only one engines cam with a new one and not the other motor too? Also looking at a crusader parts manual there is a LH cam and a RH Cam. Good luck my boating friend! I bought 1986 long blocks out of Boston back in 2013, goggle engines and rebuilders in Boston. :beergood:
Been thanked: 490 times
Postby waybomb » January 17th, 2025, 9:45 am
If you can find the original specs for the cam, most cam companies like Bullet will grind you one.
Postby km1125 » January 17th, 2025, 10:21 pm
You can try Michigan Motorz in Michigan. They provide short and long block but would probably know (and might have) the cam you're looking for.
Postby Viper » January 18th, 2025, 9:16 am
What's wrong with the cam you have now? For the most part they can be repaired. If the lobes are bad for example, they can be brought back to spec.
Postby bud37 » January 18th, 2025, 12:26 pm
Maybe looking for a quick turn around to just buy used.....I would just check around local engine rebuilders etc. that deal with marine. Would be interesting to see if the marine cam specs were any different than the regular auto specs for that hp range though. Lots of cam grinders out there, they would have lots of specs.
Return to “Boat Parts For Sale”
