Coolant leak after sea trial
- Alastair MacGregor
- Vessel Info: "BAD MONKEY'
1999 445
Cummins
Safe Harbor Ventura Isle
Ventura, CA - Location: Ventura Harbor, CA
- Has thanked: 17 times
After spending a couple months ironing out small issues after taking ownership of my 1999 445 I had it out for a full throttle run and extended motor today. When I got back in the slip and I had a "large" coolant leak. Didn't have time for true detective work. Anyone have to deal with something similar? I would like to narrow it down before starting the trouble shooting,
- Been thanked: 654 times
Re: Coolant leak after sea trial
- Has thanked: 602 times
1999 445
Cummins
Alastair MacGregor wrote:Source of the post The engine did not overheat. It was running just above 180' the entire cruise, right around two hour
Thats good news, Chances are then the cooling system pressure was holding , ya need the pressure to help control the temp....check all the fittings etc though like has been said.
1999 445
Cummins
1999 445
Cummins
So not coolant: So much water was being jetted around the engine compartment, cannot call it an engine room on a 445, from the leaking bellows that some of the oxidized bronze (blue/green) had dissolved into the water and accumulated into the bilge. PSS bellows are shot and being replaced as soon as I can get the boat into the yard. Boat life is so much fun! Thanks for all the input
Users browsing this forum: No registered users and 6 guests
