350 Aft Cabin Hydraulic Steering Pressure
- Captain Sid
- Vessel Info: I'm looking for more information on Carver Yachts before purchase.
Re: 350 Aft Cabin Hydraulic Steering Pressure
If the pressure is low, you can top it off with a regular bike pump or small tire compressor. Don't exceed max pressure though.
If the system continually loses pressure, then you have a leak somewhere, which should be found and fixed before it does become a problem with controlling the vessel.
- Captain Sid
- Has thanked: 603 times
Captain Sid wrote:Source of the post During survey the surveyor found that the steering pressure was at 10 lbs. I understand that it's supposed to be 20-25 lbs. I didn't get to see what he was looking at, but pretty sure he saw a gauge. Question is how do you increase the pressure in the system?
Just noticed this.......One thing to note here, an old pressure gage can give the wrong reading, I would double check the system with a known good gage then you can be sure of any repair being at the correct pressure.
- sbb2112
- Vessel Info: 1982 Carver Monterey 2687
260 Mercruiser / Mercruiser Alpha sterndrive
1992 Carver 350 ACMY
454 Crusaders with V-drives - Location: Michigan
- Has thanked: 2 times
- Been thanked: 10 times
