Transducer?
- sdsurf
- Vessel Info: 1977 Carver 2276
- Has thanked: 5 times
Transducer?
On the bottom of my boat I have this sensor? Anyone know what it might be? The wire coming off of it looks like a radio antenna wire or RCA cable.
Thank you
Re: Transducer?
Re: Transducer?
- sdsurf
Re: Transducer?
Re: Transducer?
If you're going to put a new one in the same spot, figure out the angle of the hull at that location and get a ducer that's designed to work at that angle without having to use a fairing block which you'd have to cut on an angle to match the hull. It might be a little more expensive but will save you time on the installation, and it will sit flat on the hull rather than having a block there that could cause drag.
- Has thanked: 602 times
Re: Transducer?
One other to consider is a shoot thru the hull type.....many ways to do that that work just fine unless you want to see the bottom over 1000'.....
and bonus no holes.-
Re: Transducer?
- ttcrocker
- Vessel Info: 1993 Voyager 330 Convertible
- Has thanked: 2 times
- Been thanked: 2 times
Re: Transducer?
Re: Transducer?
EDIT: I'm not sure about the one with the narrow neck in pic#3. I'm wondering what that looks like under the boat. The big one next to it looks like an old Datamarine speed sensor (with a wheel), because that pin could be pulled to pull the sensor out and clean debris off the wheel while the vessel was still afloat.
Re: Transducer?
