Swim platform repair
- feeez
- Has thanked: 52 times
- Been thanked: 66 times
Your opinions and suggestions as always are welcome
Fraser
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 88 times
Re: Swim platform repair
Also, did you fill the holes with epoxy before using the caulk/sealant? If not, my advice would be to re-drill out the holes, put some backing tape on the underside, and fill the holes with epoxy. Once the epoxy cures you can finish the topside to match. Caulk by itself does not work well to seal holes drilled through, and that can lead to water intrusion into the core and eventually cause the core to fail.
Lake Norman, NC
Carver 3227 - "Splashy Lady"
Users browsing this forum: Google Adsense [Bot], KyleR and 37 guests
