Starboard temp increase
- BRHEAUME
- Vessel Info: 1995 Carver 355
- Has thanked: 11 times
- Has thanked: 602 times
Re: Starboard temp increase
If you have this option, is the stbd. or port engine connected to the water heater ?
Check the thermostat itself, perhaps the engines have different thermos in them. there will be an approximate opening temp stamped on it somewhere. Unfortunately you will have to open the housing though, perhaps need a new gasket after.
- BRHEAUME
- BRHEAUME
FWC
101999 is the serial
Impellors are 2 years old
New Water Cooler
Heat Exchanger flushed/cleaned last year
Then on one trip back it climbed up 10 degrees more than before, if this is so then make sure your sea strainers are clear and the lids sealed tight if you have them. Also blow out the intake hose back thru the hull sea cock to make sure the line is clear and you haven't sucked up a bag or something therefore restricting the flow there. That can be done with a shop vac on blow, works real well. Verifying good cooling water flow thru the engines is always good practice and an easy to do first step.
- thatchh
- Vessel Info: 2004 Carver 396ES gas Crusader 8.1
- Has thanked: 5 times
- Been thanked: 11 times
