1990 3807 Head Fresh Water Pump
- chuck1869
- Vessel Info: 1990 3807
Couple of questions. If I close the seacock, will it force the head water to come from the shore water?
I can hear the fresh water pump, but cannot see it. Sounds like it is forward of the forward fresh water tank. It runs kind of loud. Does anyone know how to access that pump?
Thank you in advance to anyone that may have some guidance.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: 1990 3807 Head Fresh Water Pump
- buster53
- buster53
- chuck1869
- buster53
chuck1869 wrote:Source of the post Thank you buster53 for the replies. One head is a Jabsco. Not for sure on the other. I'll look for the pump this weekend.
Good. While you are looking, you need to find all of your seacocks and strainers and identify what each one is used for. I had 7. Find all bilge pumps, probably 3 and make sure all are in good working order. Find both sump pumps, most likely, both need a good cleaning. Find all bilge access hatches, open up to see what they give you access to. Carver is famous for putting them in hidden, out of the way places, like underneath berths, inside cabinets, under galley steps, etc. Open up your AC returns and depending on the style of filter, clean or replace the filter and inspect the inside of the return as it may need a good cleaning/vacuuming.
If your fresh water pump doesn’t stop running, you’ve either got an empty tank, the pump is faulty or you have a plumbing leak. Do yourself a favor, if you have to replace the pump, relocate it. I installed mine in the engine room on the forward bulkhead right in the middle where I can easily get to it. It’s an easy install and very convenient when winterizing.
- buster53
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 138 times
Also, some freshwater pumps, like our Shurflo Aqua King 2, have a pressure switch AND a bypass valve built into the pump, both of which are adjustable via a very small allen wrench. We had an issue with ours running for no reason and I ended up tweaking those setpoints until it operated correctly. There are videos on YouTube showing how to make the adjustment.
Might not be your problem, but definitely something good to be aware of!
2002 Carver 396
