Where is the filter for the waste holding tank on 1988 Santiago?
ADDubo
Vessel Info: 38 1988 Carver Santiago
Happy Ours
Has thanked: 2 times
Postby ADDubo » August 15th, 2025, 9:32 am
Good morning,
We are looking to change the filter/cartridge to eliminate odor when flushing the head. Last thing to try, new head, new duck valve routine cleaning and pump out. We believe the holding tank is under the forward berth, assuming there must be a filter between head and holding tank. Could not find any information in the manual.
Any help will be greatly appreciated.
Thanks,
ADDubo
Re: Where is the filter for the waste holding tank on 1988 Santiago?
Postby g36 » August 15th, 2025, 9:53 am
Most likely you will find no filter and if you did it would be on the vent hose going to the through hull. Not between head and tank. A filter can be made easily or purchased and installed if you like.
Postby g36 » August 15th, 2025, 9:56 am
You generally arent going to completely eliminate all odor. I also use this product...https://marinesan.com/noflex-digestor/? ... CkQAvD_BwE
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Postby buster53 » August 15th, 2025, 11:52 am
Now is the time to get to know your boat. Open up every bilge opening you have to see what it gives you access to. FYI, Carver is famous for putting access ports in hidden, out of the way places...under berths, inside cabinets, under stairs, underneath carpeting, etc. Find all bilge pumps and make sure they are in good working order. Find your thru hulls and attached strainers and figure out what each one is used for. Find your holding tank. Find your sump pump and it probably needs a good cleaning. Find your air conditioning water pump. Speaking of AC, clean your AC filters and vacuum the ductwork behind the filters. Find your onboard water pump for when you are not connected to shore water. I'm on my second Carver and had to replace water pumps on both. One wasn't too bad, but the other took the better part of 2 hours to replace.
Postby bud37 » August 15th, 2025, 1:05 pm
Welcome to the forum. I second the no flex digester.
One of the reasons for the odor can be there is not enough air getting into the tank to break things down so to speak. Be sure the vent line is clear as a start and try not to have any odd chemicals put in the holding tank. Flush the tank a few times to get a good start. The no flex is a different product.
There is lots of good info on line about the proper use and maintenance of marine toilet systems so you can enjoy your boat better.....good luck with your new boat.
buster53
Postby buster53 » August 15th, 2025, 2:32 pm
Anything you want to know about marine heads and sanitation, google Peggie Hall aka Headmistress. She is a “cesspool of knowledge” pun intended. She has actually written a book on the subject, is well known in the marine world and active on trawlerforum.com
Users browsing this forum: Google [Bot] and 37 guests
