Drain tube splash guard
- CooperB
- Vessel Info: 2006 39my
Re: Drain tube splash guard
That looks like a hooded drain thru-hull fitting. See if Marine Town still carries them....
https://www.marinetown.com/
https://www.mtonauticastore.com/pvc_sea_discharge
- CooperB
That being said, the fuel units are made for 5/8" hose, worst case scenaron is you will need to enlarge or reduce the hose size if i is not compatible with the OEM size hose.
Here are some examples. Perko makes one that is quite similar to the existing model if you scroll down a bit.
https://defender.com/en_us/catalogsearc ... ule%20vent
Seadog also has one available made of Nylon which would hold up much better then PVC. Only available in black though.
https://www.boatid.com/sea-dog/straight ... 5395218276
- Has thanked: 602 times
Another way to clean it up if you want , just fit a clamshell cover over that broken end there just leave the existing where it is.. They come in all kinds of sizes, finishes.
bud37 wrote:Source of the post To add.
Excellent suggestion.
Users browsing this forum: No registered users and 49 guests
