Transmission fill tube
- RyDrew
- Vessel Info: 2004 360 Mariner
Purchased on October 14, 2025 - Location: CT
- Has thanked: 1 time
- Been thanked: 2 times
Thank you
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: Transmission fill tube
- Been thanked: 490 times
Open every hatch, every cover and explore. Write down the model numbers of everything you find. You'll be happy you did.
- buster53
waybomb wrote:Source of the post You can do almost anything on that boat.
Absolutely. Find all through hulls and strainers, and figure out what each one is used for. Find all bilge pumps and make sure they are in good operational condition. Find your sump pumps and FYI, they probably need good cleaning. Find your AC water pump. Find your onboard water system pump.
Just a head’s up…Carver is famous for putting bilge access ports in hidden, out of the way places, inside cabinets, under stairs, under carpeting, etc. I’ve had my boat for 7 years and just a few weeks ago, I found a couple openings I didn’t know I had.
- Has thanked: 602 times
Users browsing this forum: foresteng@aol.com and 24 guests
