Crusader 350XL 5.7 270HP LOCKED 94 Carver 300
- ariannamarie1026
- Vessel Info: 1994 Carver 350 aft cabin
- Has thanked: 8 times
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Re: Crusader 350XL 5.7 270HP LOCKED 94 Carver 300
- ariannamarie1026
- Has thanked: 603 times
km1125 wrote:Source of the post I wonder what the oil looks like. Also, you might have someone pull the spark plugs to see if any have evidence (or actual) water in them.
Yeh I agree......if the engine is stuck and was never turned over full of water then it can be saved IMO if it didn't sit for a great length of time. Too bad ya can't find a decent mechanic to consider that, or maybe they have ??
FYI....Try not to attempt to turn the engine by hand with that crank bolt, risk of breaking that is big.
I guess if ya just want out then someone will come along and buy it from you.....I can see the merit in that as well. Good luck going forward, really too bad about all the circumstances.
- ariannamarie1026
- Cooler
Good luck!
- ariannamarie1026
- Been thanked: 491 times
Borescope each cylinder. Then put a couple ounces of dexron in each hole and let it sit for a week.
Really should remove the damper and use a crank hub tool with a 4 foot breaker bar. Use the crank hub tool and work the crank back and forth forcefully. Don't do this with the bolt, you'll just loosen it one way and probably break it the other way.
Once you get it free, rotate many many times to get as much oil out of the cylinders as possible. Then pull the distributors and use an oil pump drive to to drive the oil pump with a drill to circulate oil extensively. Then change the oil.
I've freed quite a few engines this way, including the two in my 3697 that sat outside unused for ten years.
