Propellers shafts seals and bearings
Punch'Eau
Vessel Info: 2000 350 Mariner
Has thanked: 25 times
Been thanked: 7 times
Postby Punch'Eau » October 15th, 2025, 11:37 am
2000 350 Mariner. I think my propellers shaft are on the end. What do you think? I am new to shaft propelled boats.
The shafts are 1 1/2.
Easy to do? Seals and bearings easy to find?
paulr
Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
Has thanked: 56 times
Been thanked: 32 times
Re: Propellers shafts seals and bearings
Postby paulr » November 9th, 2025, 7:30 am
Inside the strut there is a rubber cutlasss bearing. Unless you have significant experience and the right tools I would not attempt that job.
Regarding removing the prop you need a heavy duty puller and maybe a torch for some heat to get it off. Once its off it should be sent to a prop shop to be reconditioned. If you have no experience installing a prop on a tapered shaft you should get a pro to hone and torque done the nuts when its reinstalled.
Punch'Eau
Postby Punch'Eau » November 9th, 2025, 7:40 am
Thank you. I have the skills but not the tools so I will follow your advice and have it done by a pro
Postby Viper » November 9th, 2025, 9:07 am
Ya the key here is having the right tools, makes it way easier, otherwise this can totally be done with some guidance if you're mechanically inclined. New bearings shouldn't be a problem to source, you just need the outside and inside diameter, sounds like the ID in your case is 1-1/2" They come in pretty standard lengths 6-8" for small pleasure craft applications.
BTW, looks like someone put a tool on the shaft to spin it which in a no no. They should use the prop to turn it or if the prop is off, use an adjustable wrench around the shaft with the key installed. The key will act as a stop for the wrench to allow turning the shaft. If you can't turn the shaft by hand or with a wrench as described, lube the bearing with a spray lubricant or water. If you still can't spin it that easily, there's a problem, it's either misaligned, bent shaft, etc. You don't want to mark up the shaft anywhere in case you or a shop needs to dial it in the future.
Users browsing this forum: No registered users and 45 guests
