396 Aft Cabin 2000 - Bilge pumps replacements
- tgebler
- Vessel Info: 2000 396 AC
- Has thanked: 5 times
- Been thanked: 29 times
Are there any shortcuts or other helpful advice from anyone with experience? Thanks.
- paulr
- Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
- Has thanked: 56 times
- Been thanked: 32 times
Re: 396 Aft Cabin 2000 - Bilge pumps replacements
If you want to test the float switch I used a back scratcher to reach it. I forget which switch needs to be turned off. Then lift the float. if the pump doesnt come on check the breaker in the aft cabin lower fwd bulk head. I had to replace my float switch. I couldnt properly reach it because its 32 inches below the finished floor. I got my neighbor to remove and replace the switch because he was 6'3" tall and could reach it. The switch and pump are on 2 different circuits.
- paulr
7/19/2025 – Changed out FWD bilge pump Float Switch. Note: The FWD bilge pump can be turned on manually with the bridge switch “on” but the breaker in the solon must be on. When leaving the boat turn off all bilge pumps.
Float switch for forward bilge has its own 12-volt source with an emergency breaker in the AFT State Room; this is a great redundant 12-volt source of 12-volt power for the pump. The float switch breaker inn the aft cabin is connected directly to the battery.
- drbulloc
- Vessel Info: 2000 Carver Motoryacht 396 8.1 motors
Users browsing this forum: Google Adsense [Bot], KyleR, MrMojoRisin and 33 guests
