86 Mariner 3697 steering issue
- Been thanked: 490 times
Re: 86 Mariner 3697 steering issue
- MrMojoRisin
- Vessel Info: 1986 Carver Mariner 3697
- Has thanked: 32 times
Eric
2012 Larson FX1850
- MrMojoRisin
Eric
2012 Larson FX1850
Looks like your tie-rod is bent too.
- MrMojoRisin
I'm resigned to having to replace it, just need to find out if it's a K-19 or k-18. Wasn't smart enought to take a pic of the label on the cylinder while i was there last.... looks like I have another 2+ hour trip up to the boat in my future.
Eric
2012 Larson FX1850
Hynautic is made by Teleflex Marine (the same makers as SeaStar, BayStar and Capilano steering systems).
The following parts for Hynautic are still being made
- H-20 series helm pumps
- H-40 series helm pumps
- K-6 Outboard Steering Cylinders
- K-18 and K-19 steering cylinders.
ALL seals are still available (see link below for seal kit details)
http://ww2.seastarsteering.com/REPLA...TS/replace.htm [note:that link was non longer good)]
Anywhere there is a SeaStar, or, Capilano Steering Cylinder that has the same stroke and output force as the older Hynautic, Teleflex opted to use SeaStar and Capilano Cylinders only. There are some slight installation modifications that may need to be done to get the new cylinders to work, but this is minor.
ALL SeaStar and Capilano helms will work just fine with any Hynautic helm and cylinder.
- MrMojoRisin
I was undecided on whether to go with a used K19 or just bite the bullet and get a new Seastar HC5323-3. Found a used k19 for $300 on eBay, but once you figure in shipping, tax, and a seal kit I was going to be over $400. I was able to find a new Seastar from Seatech Marine Products in CA for $599 including tax and delivery. So I went that route. More than I was hoping to spend, but I won’t have to mess with rebuilding a 40 year old cylinder. Just need to install it and then bleed the system.
Eric
2012 Larson FX1850
- MrMojoRisin
I went up this past weekend with the intention of doing the swap of my broken Hynautic K-19 with the new Seastar HC5323-3. I knew there wasn't much room to work in that center hatch, so I took what tools I thought would be needed. Unfortunately I was utterly unprepared for taking the exhaust hoses off to clear some space. So, I now have an 8 pc pick set, some water pump pliers and PB blaster and will be going back up to try again. Hopefully I make it a step further this time.
Not sure how you guys manage working on a boat that is 2+ hours from your home... Can't wait to get this thing back to our home port so I'm only an hour away.
Eric
2012 Larson FX1850
- MrMojoRisin
Eric
2012 Larson FX1850
Users browsing this forum: No registered users and 56 guests
