360 Sport Sedan Bridge removal 2003 (or 04)
- camelot
- Vessel Info: Carver 360 SS
- Been thanked: 2 times
I am not QUITE a Carver owner yet, but set to do a Sea trial on a 2003 360 Sport Sedan this week. If all goes well, I own it on the spot and I will need to remove bridge and truck it to the St. Croix River. My question is: does anybody have any helpful hints, best practices, or just good advice you could share on this particular procedure on this particular boat?? ? I have hired a crew that has done a lot of bridge removal/reassembly, but I just wanted to be armed with as much info as possible since every boat configuration is different and want this to go smoothly.
Thanks in advance!! Here's to a great summer on a Carver!
Wild River Yacht Club
St Croix River - Hudson WI
- Ramsport47
- Has thanked: 72 times
- Been thanked: 59 times
Re: 360 Sport Sedan Bridge removal 2003 (or 04)
T-Merc 350 Mag MPI (300hp)
- camelot
It sounds like just the throttle and steering cables are the only part that is not plug and play...
mcgedb
- camelot
Yes - bought the boat, removed the bridge and put it all back together - I had the help of our Harbormaster from my marina, but it was fairly straightforward - just a lot of screws around the inside and a few on the back above the sliding door - and everything except for the throttles were unpluggable. Came back together great - very tight exact fit - the screw holes all aligned in the first try! Let me know how your project is going or if you need and specific advice!
