Props
- joeslenzak@gmail.com
- Vessel Info: 2002 Carver 410 Sport Sedan
Props
I have a 2002 410 Sport Sedan. The props were changed out at some point by the original owner. It has twin Cummins diesels (370 hp). It struggles to get on plane unless I turn the steering wheel and then it seems break free and come onto plane. Current props are 24x29. I am trying to find out what the original props were on this boat. I think the replacement prop pitch may be too much.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: Props
- Has thanked: 602 times
Re: Props
Re: Props
There are a few things to cross off before the prop consideration.
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 138 times
Re: Props
However, that was for an empty boat with probably not a lot of fuel or water and no personal items. When we bought the boat in 2022 it would only make 2700rpm ar WOT with a clean bottom and none of our "stuff". After two years and fully loaded with a not-so-clean bottom, it only made 2400 rpm at WOT. Obviously WAY overloaded so we basically ran it like a trawler for the last year+ to keep the engine from working so hard.
We just launched today after a month in the yard and now have a very clean bottom and we swapped out the props out for 24×25.5, so we'll see what happens. We're staying on anchor for a few days to chill out and recover but I'll post back once we run it up.
Anyway, long story short, you definitely sound overpropped. Those engines should be able to spin at 3100-3150rpm, under load, at WOT.
Kyle
2002 Carver 396
Re: Props
Let me know how the new props perform
Joe
- KyleR
2002 Carver 396
Re: Props
One other thing I noticed was that my throttle levers at the helm were pegged against the dash, so there may have still been additional throttle movement available at the engine if I tweak the cable mounts. I'll be exploring over the next week or so.
2002 Carver 396
Re: Props
- Chocura370
- Vessel Info: 1993 Voyager 370
Re: Props
buster53 wrote:You may be over propped. What is your WOT RPM and what is the engine mfg’s recommended max RPM? We need the answer to those 2 questions before any recommendations can be made.
I have same question & situation going on with my ‘93 370 Voyager. I’ve been reading all the post on this topic, and repeatedly see this same question being asked:
“What is your WOT RPM and what is the engine mfg’s recommended max RPM? We need the answer to those 2 questions before any recommendations can be made”
I don’t know how to find the answers, my props are damaged. The engines are original equipment Mercruiser 7.4 gas. How do I know what the max RPM should be? Basically Chevy big block……. I don’t think anything over 3500 rpm continuous would be good for these engines.
Also, most boats at my club all have 3 blade props but min are four blades. Why? What difference does it make?
I pulled the damaged props today. They are roughly 18 inch diameter, shaft size 1-3/8”, stamp on the hub says 18p 21.5. Is there anyone here who will kildy help me figure this out?
- buster53
Re: Props
I believe those engines should max out in the 43-4500 range. No, you don’t run them continuously at that speed, but you do need to open them up from time to time to make sure you are getting full RPM’s
Take your props to a good prop shop. They will fix whatever is wrong and give them back to you looking brand new. They can also give you advice as to what is best for your boat if what you have aren’t the right ones
Users browsing this forum: Google Adsense [Bot] and 63 guests
