2002 Carver 346 Trim Tabs - Can I add a gauge?
- NHCarver346
- Vessel Info: 2002 Carver 346
Mercruiser 6.2L
220 Hours Freshwater - Location: Gilford NH
Would be nice to know the position of the trim tabs vs. just pressing the dash toggle UP or DOWN not knowing when the tabs hit their stops (as I dont have a dash gauge). Currently I just keep pressing the button and holding for a while assuming eventually I will be all the way up (or down), not sure if that does any harm to the hydraulics either.
Does anyone know what brand Carver used and if they have any sort of a position wire that might work with a trim tab gauge that I can still purchase? There are some outboard 2" gauges that look at resistance and then of course there is an entire new setup with hydraulics, wiring, UP DOWN buttons and a gauge.
My tabs still work fine so just looking to install a compatible indicator on my dash.
Re: 2002 Carver 346 Trim Tabs - Can I add a gauge?
To add the displays you have to change the hydraulic cylinders with the new ones having the sensors built-in.
- Been thanked: 654 times
https://bennetttrimtabs.com/product/autotrim-pro-sensor-kit/
- kgarguilo
- Vessel Info: 1999 Carver 406
- Has thanked: 197 times
- Been thanked: 55 times
1999 Carver 406
- sbb2112
- Vessel Info: 1982 Carver Monterey 2687
260 Mercruiser / Mercruiser Alpha sterndrive
1992 Carver 350 ACMY
454 Crusaders with V-drives - Location: Michigan
- Has thanked: 2 times
- Been thanked: 10 times
- Has thanked: 602 times
I remember from years back refitting insta trim to Bennett on another boat. Bennett was extremely customer friendly as far as after sale help. Now the guy that I dealt with may be gone now, as I remember he had a presence on a forum, don't remember what one.
FYI...if you decide to change these out, be aware to follow instructions closely when it comes to screwing that bronze threaded nipple into the plastic housing. You could crack that housing if too tight or have a leak if too loose and not done right. Now that said, perhaps the newer versions no longer have that make up or at least better engineered fittings.
For me though tabs are just for getting the boat attitude the best for the sea and wind conditions which constantly change so there would be no regular setting IMO. Always ran the tabs full down for the in the marina manoeuvring not backing down though !!, it slowed the sudden boat movements down a bit.IMO.
- sbb2112
bud37 wrote:Source of the post Yup, we had an 01 and it had Bennett tabs on it. Insta trims have the hydraulic hose on the outside going to the ram, the Bennetts have the fluid going thru the transom fitting that is flexible. At Least they used to be that way for some years. The dash rockers can be retrofitted so I wouldn't go by that alone.
Yes, same plastic piece where brass tube is screwed into. Would have been better to have metal insert to screw into. Just have to be careful
