fuel shutoff valves 97 355
Topic author
essikr
Vessel Info: 1996 355,twin gasoline engines
Postby essikr » June 28th, 2013, 9:47 pm
Where are the fuel shutoff valves located? Twin 456 gasoline engines 1997 Carver 355.
The fuel gauge switch toggle between starboard and port plus aux tanks.How do you read the aux tank level.
Thanks for your help.
AaHubb
Vessel Info: '99 404 CPMY
my twin diesel pusher
Has thanked: 15 times
Been thanked: 61 times
Re: fuel shutoff valves 97 355
Postby AaHubb » June 29th, 2013, 11:02 am
On my '99 404 the fuel gage on one side of the dash is for the saddle tanks and the gage on the other side is for the aux tank. Each gage has a related switch to get a reading. As for the fuel cutoff valves mine are on the bulkhead forward of the engines next to the Racors.
'99 404 CPMY
SeaDragon
Topic author
essikr
Postby essikr » June 30th, 2013, 12:08 pm
That explains the fuel gauges, thanks. Now if I can just find the fuel shutoffs. I have looked in all the places you would expect them to be.
Been thanked: 491 times
Postby waybomb » June 30th, 2013, 5:28 pm
Not familiar with a 355, but can you get into the engine room and follow the fuel lines back? First termination after the filter back to the tank should be the valves.
fwiw - both my 1988 28 Aft and my 89 42 aft had no shut offs. My 87 36 has them but you have to get down in the engine room to see them / reach them.
trmnewt
Vessel Info: 2000 Carver 506
Postby trmnewt » September 14th, 2013, 2:03 pm
I had a 96 355 and e fuel shutoffs were under a hatch in the salon floor, just to the left of the stairs as you enter the cabin, all the way aft. A corner of the sofa sits on it1--kind of a pain
Users browsing this forum: No registered users and 37 guests
