Windlass pressure arm replacement?
- Wkuhilltopperfan
- Vessel Info: 1998. Mariner 350 . Twin 7.4 engines / kholer 6.5 gas Genset
- Has thanked: 17 times
- Been thanked: 18 times
1998 350 Mariner
Thank you
Re: Windlass pressure arm replacement?
- Wkuhilltopperfan
http://www.maxwellmarine.com/support_manuals.php
- Wkuhilltopperfan
Wkuhilltopperfan wrote:It won't load with my IPad but I'll pull out my computer tomorrow. Thanks
These units aren't made anymore so when you buy the pressure arm, you may want to consider buying two as I suspect they will eventually be harder to get and more expensive. They are a normal wear item so if you're keeping the boat for a while, you may eventually need to replace it again. While you're in there for the pressure arm, check the condition of the stripper.
- Wkuhilltopperfan
Users browsing this forum: waybomb and 29 guests
