350 Mariner Port Engine over heats at idle
- Finest
- Vessel Info: 1997 Mariner 350
Twin 350 Crusader Engines - Location: Penetang, Georgian Bay
Raw water side:
Rebuilt Raw water pump, flushed Transmission cooler, Had the heat exchanger removed cleaned tested and re-installed & flushed the raw water system.
Closed loop side:
Replaced thermostat, flushed and replaced antifreeze.
Flushed and changed oil in both engine and transmission.
The unusual thing is it only happens some time and only when I am in gear and at idle to dock or anchour, as soon as I bring the rpms up to 1000 it cools right down to 165. Any help will be great.
- Has thanked: 603 times
Re: 350 Mariner Port Engine over heats at idle
There could be some air trapped in your closed cooling side and the second ,more work, would be that the engine circ ( water) pump has a problem...( impeller vanes corroded,belt slipping,impeller loose on shaft).See if you can verify good water circulation at idle in your closed side first, hopefully something simple.
Another from Penetang , small world.
When you rebuilt the raw water pump, was the impeller intact? Did you backflush the system in hopes of flushing out impeller pieces that may have lodged in there from a previous impeller failure?
After Taxes
- Vessel Info: 'After Taxes'
2004 Carver Mariner 360
Lake Simcoe & Georgian Bay,
Ontario, Canada - Location: Lake Simcoe Marina
- Has thanked: 6 times
- Been thanked: 17 times
MerCruiser MX 6.2
Lake Simcoe, Ontario
