Battery charger for the generator
Topic author
Nplbw
Vessel Info: 2005 Carver 411 CMY Volvo penta d6 370 hp
Postby Nplbw » July 6th, 2013, 11:30 am
I have a 2005 Carver 411 and the battery charger for the generator does not seem to be getting power to charge the battery. I have searched for a tripped breaker but can't find one. Does anyone have any suggestions? Any thoughts would be appreciated.
Thanks,
Neil
AaHubb
Vessel Info: '99 404 CPMY
my twin diesel pusher
Has thanked: 15 times
Been thanked: 61 times
Re: Battery charger for the generator
Postby AaHubb » July 6th, 2013, 2:41 pm
My Westerbeke had a bad rectifier in the 12v charging circuit. A $2 part from Radio Shack fixed it. You need to put a volt meter on the charging leads from the genny to see if you are getting any output. There may be an adjustment point on the genny circuit board if the voltage is just low.
'99 404 CPMY
SeaDragon
Topic author
Nplbw
Postby Nplbw » July 10th, 2013, 11:56 am
I think we have isolated it to the 8 amp fuse on the AC side of the charger circuit board. Thank you AaHubb for the help.
Users browsing this forum: No registered users and 72 guests
