Cummins coolant change
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
thanx ..Aaron
SeaDragon
- ScubaPete
- Vessel Info: 2002 Carver 406
Cummins 6BTA 330's - Location: Seaford, Virginia
- Has thanked: 1 time
Re: Cummins coolant change
If your want to change the coolant anyway, then there is a drain filling on the underside of the horizontal pipe that is under the heat exchanger. Re fill slowly and bleed out any trapped air so you don't have cooling problems later on.
Makin' Waves
- Vessel Info: 1999 Carver 356 Aft Cabin with twin Cummins Diesel engines. Garmin Navigation Suite with Autopilot.
Thanks...
Charleston, SC
- Been thanked: 490 times
Try googling "marine diesel engine forum".
- CYO Admin
- CYO Administrator
- Has thanked: 269 times
- Been thanked: 29 times
- AaHubb
SeaDragon
Users browsing this forum: Google [Bot] and 12 guests
