2000 Mariner 350 - Kohler Gen
Topic author
plots10
Vessel Info: 2000 Carver 350 Mariner
Postby plots10 » August 18th, 2016, 1:49 pm
I have a rebuilt Kohler 7.3E generator that will start up without issue, but will only run for 10 seconds and shut off. So far here are the things that have been done to it in the past 2 weeks and have not fixed the problem. Can anyone give me some ideas as to what I can try next? :help:
New fuel pump
new fuel lines
new fuel filter
new impeller
new sleeve
Been thanked: 490 times
Re: 2000 Mariner 350 - Kohler Gen
Postby waybomb » August 18th, 2016, 2:05 pm
Could it be a faulty sensor shutting it down?
Water temp. Oil pressure, etc?
Postby tomschauer » August 18th, 2016, 4:04 pm
My 6.5 esv was doing the same thing. For me it was a bad control board not providing voltage to the fuel pump.
There are a couple places that will test your board and if bad repair it for about $100.00.
On another note, check your fuel pump. When I replaced my fuel filter I had to remove the pump. When I reinstalled it the genny only ran for a few minutes, then ran out of fuel. The darn pump will run backwards if polarity is wrong. I wasted a good hour on that one! :banghead:
anothernewb
Vessel Info: 2000 350 Mariner
Twin Mercruiser 5.7l Horizon
Garmin 4212
Been thanked: 21 times
Postby anothernewb » August 18th, 2016, 9:03 pm
