kohler 7.3 impeller change
- mjk1040
- Been thanked: 248 times
Re: kohler 7.3 impeller change
mjk1040 wrote:Source of the postWould area of boating have a relative effect on these impellers?...
Absolutely. Anything in the water passes through those impellers so murky sediment laden water wears the impeller a lot faster than clean water. Boating habits also contribute. If you do a lot of shallow water boating, your props will stir up sand that gets sucked into the intakes and blast the impellers.
mjk1040 wrote:Source of the post....I'm all about preventative maintenance, but also a believer in, if it ain't broken, don't fix it too....
While this is acceptable for some systems, impellers is one that if you do wait until it's broken, you could be stranded. Also consider that by the time you see a change in temps at your engine gage due to an impeller failure, your exhaust temp has already shot through the roof. Typical cause of early exhaust hose failure. It only takes seconds before exhaust temps rise to critical levels without water. Engine temps on the other hand take much longer in comparison before alarms go off. In stern drive applications this means melted shutters right away. In applications with resonators, they'll be melted too before you realize there's an overheat. This is why exhaust temp alarm systems are gaining popularity and are on my bucket list.
- Has thanked: 602 times
The one I removed had no further damage than the two torn vanes.I guess if the genny in this boat was installed so the pump was easily accessible this would be an easy 10 minute job and that is if you close one eye, lol and this thread would not even be here. Maybe give Sherwood a shout to see if they have a retrofit for this application or see what they have to say engineering wise also. Imo easy maintenance is maintenance that gets done....
- mjk1040
- CaptBob
- Vessel Info: Shopping....
- Been thanked: 33 times
More Nautiville 2004 Carver 360 Sport Sedan
A little less Nauti 2008 SeaDoo 150 Speedster (Admiral could not live without a jet boat....
)Nautiville 2005 Cruisers 280 CXi *Sold*
Nautitown 2012 SeaDoo 180 SP *Sold*
