1973 Monterey 2585 bringing her back to life
- lrfickau
- Vessel Info: 1973 Monterey 2585 OMC 225hp single IO
"SEA STAR" - Location: Lake Geneva Wisconsin
- Been thanked: 5 times
Re: 1973 Monterey 2585 bringing her back to life
Pull the plugs
Fog the cylinders
Turn engine over by hand
refog cylinders
turn engine over with starter
check spark
reinstall plugs
remove fuel line to carb
put a line from carb into a 5gal jug with fresh gas w/lead additive.
Hook up muffs to water hose
Then try to fire her up
after that check compression.
if all goes well I fallow Waybomb list and prepair for a shakedown cruise in sping.
Yes I will rewinterizer it before winter.
- Been thanked: 491 times
I attempted to break them lose using the crank bolt but that wasn't working.
That's why I took the dampener off, so I could use a proper crank hub socket to rock the crank back and forth. You won't do that with the bolt of the Rings are stuck at all.
Btw, the engines only had about 250 hours on them.
- lrfickau
Can you adapt a garden hose to the hose leading from the sea cock?
Disregard my previous comment then about getting hot
It will get empty very quickly.
- lrfickau
- lrfickau
Into a heat exchanger if fresh water cooled. Then out the exhaust manifolds and back down the drive exiting through the prop.
If the pump has any vanes on it after sitting for 16 years they will all be gone after a couple revolutionS of the engine.
Then no cooling water to the engine.
Users browsing this forum: geo and 13 guests
