airconditioning
scoobychonx
Topic author - Scurvy Dog
- Vessel Info: 1991 carver 36 aft cabin twin cummins
- Has thanked: 5 times
airconditioning
Re: airconditioning
- mjk1040
- Been thanked: 248 times
Re: airconditioning
- Been thanked: 490 times
Re: airconditioning
If you have any issue with your older ac, I strongly recommend this Webasto, but I would also guess any unit with a scroll compressor will be similarly quiet.
scoobychonx
Re: airconditioning
- CaptBob
- Vessel Info: Shopping....
- Been thanked: 33 times
Re: airconditioning
waybomb wrote:Source of the post When we bought our 3697, the forward ac was missing. It is right under the bed. The older units were loud. I bought a new Webasto. The air coming out of the vents is more noisy then the unit itself.
I appreciate this info. I'm in the middle of deciding what to do with my salon ac unit. I have a compressor hammering and on it's way out. I've been looking at replacement units, and looked into those Webasto after reading your post. A quiet unit would be a good thing!
More Nautiville 2004 Carver 360 Sport Sedan
A little less Nauti 2008 SeaDoo 150 Speedster (Admiral could not live without a jet boat....
)Nautiville 2005 Cruisers 280 CXi *Sold*
Nautitown 2012 SeaDoo 180 SP *Sold*
Re: airconditioning
- Been thanked: 654 times
Re: airconditioning
http://mmair.com/marine-division/marine ... ditioning/
- mjk1040
Re: airconditioning
Re: airconditioning
Converting to 134a requires you remove all of the oil (a difficult task with rotary compressors) and replace the oil and refrigerant. You will also need to replace the expansion valve(s) and add a filter dryer. As mentioned above with an older unit, its not worth the time and $$$.
