Rairatan icerette model 85
Reelpriority
Vessel Info: Carver 356 Aft Cabin
1999
Miss Judy, Murrells Inlet, SC
Been thanked: 4 times
Postby Reelpriority » August 22nd, 2013, 10:07 pm
Any recommendations on repair or replacement of a 1999 Rairatan model 85 icemaker? It appears that the module that contains the small motor that controls the harvest of the ice may have failed. Replacement cost is $130.00 plus.
Not sure if the other components will hold up long term. New models are $1k plus.
Thanks.
MISS JUDY
Murrells Inlet, SC
AaHubb
Vessel Info: '99 404 CPMY
my twin diesel pusher
Has thanked: 15 times
Been thanked: 61 times
Re: Rairatan icerette model 85
Postby AaHubb » August 23rd, 2013, 10:59 am
How much ice do you really need. It seems all marine/rv ice makers are pricey. One possible solution is a portable ice maker that can be stowed when not needed. Of course the cheapest is a small ice chest filled with ice from the local quick-mart.
'99 404 CPMY
SeaDragon
Reelpriority
1999
Postby Reelpriority » August 29th, 2013, 11:24 pm
Talked to rairitan tech support. Good trouble shooting process. Narrowed down the problem to the control module board. Ordered a new board on line for $114.00. Removed old module and installed new board which has a small motor that turns the ice ejection fingers. Unit is now making 22 lbs ice/day.
MISS JUDY
Murrells Inlet, SC
Been thanked: 491 times
Postby waybomb » August 30th, 2013, 11:28 am
It feels good to fix something, doesn't it?
Great job!
You can tell your wife you saved a thousand bucks and you'll be spending it on something for yourself.
Reelpriority
1999
Postby Reelpriority » September 2nd, 2013, 9:15 pm
Yep! Seems like the control module fails on these ice machines. I noticed that the previous module had a 2006 date. Looks like these modules last about six years.
MISS JUDY
Murrells Inlet, SC
