Fresh water pump
1992330aftcabin
Vessel Info: 1992 330 Carver aft cabin
Has thanked: 54 times
Been thanked: 32 times
Fresh water pump
Postby 1992330aftcabin » October 6th, 2019, 11:05 pm
I thought I would share this with you. My fresh water pump (Sure flow pump) was coming on for a moment then shut off, my first thought was I have a leak in the system. I spent several hours looking for a leak no leak found. I didn’t like listening to the pump run so I turned the pump off and ran shore water pressure, the next day I had water coming out of the fresh water tank vent. I scratched my head for a few and realized there’s only 1 check valve in the system ( hot water tank cold water inlet). I researched the fresh water pump and it has a internet check valve that was leaking and filling the water tank. I replaced the pump and both problems are gone. Hope this helps someone in the future.
Been thanked: 248 times
Re: Fresh water pump
Postby mjk1040 » October 7th, 2019, 6:33 am
Pro active issues are always a good idea!
Has thanked: 474 times
Postby Viper » October 7th, 2019, 6:59 am
Ya it's one of the common pump failures. Every pump will have an and outlet/reverse flow check valve. Some accomplish that right at the outlet port and others rely on bellows contact with internal port. Debris is usually the cause of the failure or chemicals like bleach, or high alcohol levels in cheap plumbing antifreeze. Oh Oh, there's that cheap plumbing antifreeze subject again ;-)
cmlrfp
Vessel Info: 2008 41 CMY
Has thanked: 2 times
Postby cmlrfp » October 17th, 2019, 8:40 am
Question on using dock water to pressurize your boat so you don't use the house tank..... I notice that when connected to dock domestic water supply my fresh water holding still goes down!!!! Is this normal or is there an issue with a check valve or something
2012 41CMY
Thanks all
RP
Postby tomschauer » October 17th, 2019, 9:15 am
Turn off the breaker for your fresh water pump when connected to city water.
Postby Midnightsun » October 17th, 2019, 9:56 am
Yes this is normal, you need to turn off the water pump as mentioned.
Postby km1125 » October 17th, 2019, 10:54 am
cmlrfp wrote:Question on using dock water to pressurize your boat so you don't use the house tank..... I notice that when connected to dock domestic water supply my fresh water holding still goes down!!!! Is this normal or is there an issue with a check valve or something
2012 41CMY
Thanks all
RP
Yes, like others have mentioned, kill the potable water pump at the breaker. Your pump pressure is likely set higher than the city water pressure, just like mine. If you want that extra pressure for certain uses (like a nice shower or a good deck washdown) then kick the pump on and use up some of the tank water.
1992330aftcabin
Postby 1992330aftcabin » October 17th, 2019, 12:12 pm
As stated in my original post, the water pump was coming on. So I turned off the pump and ran off city water then I had water coming out of the vent. At the end of the day I replaced my pump and resolved my issues.
Users browsing this forum: bud37 and 30 guests
