Volvo Penta 8.1l Gi-F light load miss fix
Re: Volvo Penta 8.1l Gi-F light load miss fix
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
- Cliffm
"the Condo"
- Has thanked: 260 times
- Been thanked: 21 times
Midnightsun wrote:Source of the post If you are in a salt water application I highly suggest you use Marine Grade Never Seize as the regular stuff will harden up and become Ever Seize. Personally I use the Marine grade stuff only on all applications. https://www.grainger.ca/en/product/p/LC ... Google+PPC
Excellent tip! Thanks Hans
- Has thanked: 603 times
Cliffm wrote:Source of the postMidnightsun wrote:Source of the post If you are in a salt water application I highly suggest you use Marine Grade Never Seize as the regular stuff will harden up and become Ever Seize. Personally I use the Marine grade stuff only on all applications. https://www.grainger.ca/en/product/p/LC ... Google+PPC
Just a heads up.....if you have the graphite based grease, only apply very lightly on spark plug threads ( less is better in this case ). The reason being, that stuff has a habit of taking on a life of it's own, as in "it gets everywhere".... the plug ceramics have to be clean and free of the lube or the graphite component will cause a miss condition by shorting to ground given the right path......
- pepmyster
8.1 Volvo Penta
Midnightsun wrote:Source of the post Too bad you live so far away as we buy it by the case for the shop. Would have given you an early Christmas gift.
I love Christmas, and, We don't live far!!!! Never too far for you guys!!!
