Volvo Penta 8.1l Gi-F light load miss fix
Re: Volvo Penta 8.1l Gi-F light load miss fix
Postby Midnightsun » November 4th, 2020, 6:08 am
If you are in a salt water application I highly suggest you use Marine Grade Never Seize as the regular stuff will harden up and become Ever Seize. Personally I use the Marine grade stuff only on all applications. https://www.grainger.ca/en/product/p/LC ... Google+PPC
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 210 times
Postby pepmyster » November 5th, 2020, 5:50 am
Thanks Hans, I never knew that type existed.
Postby Midnightsun » November 5th, 2020, 5:54 am
Too bad you live so far away as we buy it by the case for the shop. Would have given you an early Christmas gift. :-D
Cliffm
Vessel Info: 2006 Carver 36 MY
"the Condo"
VP 8.1Gi-F
Has thanked: 260 times
Been thanked: 21 times
Postby Cliffm » November 5th, 2020, 9:22 am
Midnightsun wrote:Source of the post If you are in a salt water application I highly suggest you use Marine Grade Never Seize as the regular stuff will harden up and become Ever Seize. Personally I use the Marine grade stuff only on all applications. https://www.grainger.ca/en/product/p/LC ... Google+PPC
Excellent tip! Thanks Hans
Postby bud37 » November 5th, 2020, 10:24 am
Cliffm wrote:Source of the post
Just a heads up.....if you have the graphite based grease, only apply very lightly on spark plug threads ( less is better in this case ). The reason being, that stuff has a habit of taking on a life of it's own, as in "it gets everywhere".... the plug ceramics have to be clean and free of the lube or the graphite component will cause a miss condition by shorting to ground given the right path......
pepmyster
8.1 Volvo Penta
Fresh water boating
Postby pepmyster » November 7th, 2020, 6:51 am
Midnightsun wrote:Source of the post Too bad you live so far away as we buy it by the case for the shop. Would have given you an early Christmas gift. :-D
I love Christmas, and, We don't live far!!!! Never too far for you guys!!!
Users browsing this forum: No registered users and 9 guests
