Kohler 10 kw genny (Model 10e) hard to start
- Mikwallace
- Vessel Info: 1998 Carver 405 AC 7.4 Horizon engines
- Has thanked: 117 times
- Been thanked: 23 times
1998 405 Aft Cabin
My generator has always been hard to start. It would take 20-30 seconds of starter operation to start the Generator. I never held the starter button for more than 10 seconds before I’d give a 3 second pause. Once started the generator worked as advertised.
Finally yesterday after 1.5 years of ownership I decided to fix it. Simple fix!
The choke needed adjusting.
Here’s a pic of the generator. I’ve an Ohm meter connected to the choke heater wire to check voltage.
Here’s the choke at cold temp. As you can see it’s not closed. I guess through the years of operation the spring gets weak and won’t close the choke completely?
And finally the voltage to the choke spring.
1979 Caravelle 18’
- Been thanked: 490 times
Re: Kohler 10 kw genny (Model 10e) hard to start
If it doesn't, then you need to replace the choke thermostat element.
- Been thanked: 654 times
- Has thanked: 602 times
- Mikwallace
km1125 wrote:Source of the post That choke thermostat element is adjustable, right (the three screws holding it in place?) I'd adjust so the choke closes all the way, then just hook 12VDC directly to it for about 5 min and see if it opens all the way.
Yes, I did exactly that and it works great! I was a little suspicious that I might have to replace the 26 year old spring, but it worked fine. Even went back later to see if it closed after cooling and it did!
1979 Caravelle 18’
Users browsing this forum: Google Adsense [Bot] and 55 guests
