Kohler 10 kw genny (Model 10e) hard to start
Mikwallace
Vessel Info: 1998 Carver 405 AC 7.4 Horizon engines
Has thanked: 117 times
Been thanked: 23 times
Postby Mikwallace » July 3rd, 2024, 12:47 pm
Background:
1998 405 Aft Cabin
My generator has always been hard to start. It would take 20-30 seconds of starter operation to start the Generator. I never held the starter button for more than 10 seconds before I’d give a 3 second pause. Once started the generator worked as advertised.
Finally yesterday after 1.5 years of ownership I decided to fix it. Simple fix!
The choke needed adjusting.
Here’s a pic of the generator. I’ve an Ohm meter connected to the choke heater wire to check voltage.
Here’s the choke at cold temp. As you can see it’s not closed. I guess through the years of operation the spring gets weak and won’t close the choke completely?
And finally the voltage to the choke spring.
1959 Larson 16’
1979 Caravelle 18’
:captain2:
:usa:
Been thanked: 490 times
Re: Kohler 10 kw genny (Model 10e) hard to start
Postby waybomb » July 3rd, 2024, 1:41 pm
Good job!
Postby km1125 » July 3rd, 2024, 4:38 pm
That choke thermostat element is adjustable, right (the three screws holding it in place?) I'd adjust so the choke closes all the way, then just hook 12VDC directly to it for about 5 min and see if it opens all the way.
If it doesn't, then you need to replace the choke thermostat element.
Postby Viper » July 3rd, 2024, 7:10 pm
:down:
Postby g36 » July 3rd, 2024, 7:32 pm
Same genset in my 405 I had to do that at one time also. I marked it so I knew where I started if I ever needed to go back. Appreciate you posting it in case others need the info.
Postby bud37 » July 3rd, 2024, 7:55 pm
Thanks for posting......
Mikwallace
Postby Mikwallace » July 3rd, 2024, 11:58 pm
km1125 wrote:Source of the post That choke thermostat element is adjustable, right (the three screws holding it in place?) I'd adjust so the choke closes all the way, then just hook 12VDC directly to it for about 5 min and see if it opens all the way.
Yes, I did exactly that and it works great! I was a little suspicious that I might have to replace the 26 year old spring, but it worked fine. Even went back later to see if it closed after cooling and it did!
1959 Larson 16’
1979 Caravelle 18’
:captain2:
:usa:
Users browsing this forum: Google Adsense [Bot] and 54 guests
